Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Installation & update
crushes after objects editing
AC11 on Vista. any editing of objects or doors leads to crush and bug reporter.
2 REPLIES 2
Thomas Holm
Not much to guess from. I can only say re-install from your CD and re-apply the latest update (Help>Check for updates).
If you have not manipulated the Graphiosoft folder, this takes some time but should not be a big problem. Also, have at least 2GB of RAM in your machine.
Djordje
What are your machine specs? Compare them tot he minimal requirements and see whether you have more than listed. The old CAD rule says that you should always have twice the required for the smooth operation.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
