dialogue boxes graphics problem
i'm having issues with what i a ssume is a graphics card issue - dialogue boxes appear with segments missing (archicad main window showing through); clicking on the area where dialogue box items should be usually makes them appear, usually individually. i've attaged a screen shot...
problem also occurs with navigator window when it is in 'floating' mode; when locked to side of window, it appears ok.
any advice appreciated - thanks in advance
here is image...
Bob
I have had similar issues when using older Cadimage add-ons (eg. DWB 8 on AC10). It looks from your image like this may be the case here too. Are they up-to-date and appropriate for your AC version?
stuart,
cadimage tools could be contributing to problem...i'll go to their website to see if any note has been made; however, this is only occuring on my work computer (recently purchased) while i have had no such issues on my (lower spec) home computer - all software is the same (latest versions).
bob
