Project data & BIM
entering numerical infomation for moving, length of elements
I hope this is simple - I thought that when drawing a line, you could just click a start point and drag along a direction then type a distance and press return to complete the line. I am told that you have to use the coordinates pallete and type R then the distance. I was sure that I had done it without the R, just by typing a distance. Is this possible or am I confused?
Thanks, Matt
TomWaltz
It's possible in Archicad 10 if you have the Tracker turned on.
Tom Waltz
Thank you, I knew it was there somewhere!
