shortcut schemes
in ArchiCAD 9, is there a way to import custom configured shortcut scheme under work environment from one computer to another one, or do I need to punch eachone all again?
thanks in advance
6 Replies 6
Djordje
Yes there is.
First save your scheme/profile, then you can import it wherever else.
On Windows, they are by default at
C:\Documents and Settings\<username>\Application Data\Graphisoft\<ArchiCAD version>\WorkEnvironment\Profiles
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
what about macs?
anybody have an idea?
TomWaltz
/Users/UserName/Library/Preferences/Graphisoft/<archicadversion>
You can also use the Work Environment to Export your settings to wherever you want.
Tom Waltz
thanks I got them all now
Djordje
Should I remind for the millionth time that all should put their Archicad, OS and computer specs in the signature?
Djordje
HP Omen
TomWaltz
I thought that was going to be a requirement when signing up
Tom Waltz
