Installation & update
exporting to an ifc format
hi i was wondering if any one can help me? i trying to make a ifc file in archicad. is there any way i can translate and make a model in the building from a .pla to a .ifc???
1 REPLY 1
Ben Odonnell
Ivan,
There sure is. What version of ArchiCAD are you using? If it's ArchiCAD 9 a simple Save as then change the file formate from PLN to IFC.
If it's another version of ArchiCAD you will need to download the respective IFC add-on. You can get them here http://www.graphisoft.com/products/ifc/
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
