help why AC 12 crashes on opening color picker...
In materials settings dialogue box, whenever I try to change the colour in colour palettes it stacks and even force ArchiCAD not to respond. I can't do anything unless close AC. What is the problem?
-AC is working well other than this,are there uninstalled components in my AC12 installation?
Thanks.
3 Replies 3
if you post what machine and OS you're using and if your v12 is fully up-to date, someone may be able to help you.
MY MACHINE HAS GOT:
MS Windows Xp professional
Service Pack 2,version 2007-2008
Intel(R)4 CPU 1.7GHZ, 1.25GB OF RAM.
ARCHICAD 12
2156 INT FULL FOR TEAMWORK
Heynock,
I've merged your duplicate thread with this one. Please do not start a new thread just because you did not get an answer to an old one.
You should contact your local Graphisoft technical support perhaps?
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
