2003-12-11 09:26 PM - last edited on 2024-03-27 03:19 PM by Aruzhan Ilaikova
2003-12-11 09:48 PM
Shae wrote:shae,
Windows cannot find the wibu key.
2003-12-11 09:53 PM
aahatimo wrote:Yes I am on XP and I followed the instructions, with one small detail, I uninstalled 8.0. I guess this caused some problems. In the past this as been the modus operandi. I didn't see anything to the contrary. Now WIBU doesn't work. I can't even open 7.0. We also have an HP 500, but it is installed on another machine. What Can I do? RIght now I am installing the update from the WIBU website which the home page is busted for. Luckily someone posted a link to thier update page.Shae wrote:shae,
there was a letter in the 8.1 upgrade pack. are you on xp? sounds like some sort of drug.... there are also osx install notes.
you need to unplug the key before installing 8.1, then reboot & install the key. i actually turned machine off inserted key then started it up.
drivers are on the disk. also new drivers are @ the
http://tr.graphisoftus.com/
site gs-us has WIBU Drivers version 4 for Windows & osx to download, the disk has 3.x.
i have had to uninstasll/reinstall many times recently due to a hpgl2 upgrade for my hp500 plotter. key has been recognised each time.
good luck! this rapid forum is great.
2003-12-11 10:06 PM
Shae wrote:i am sure you have uninstralled / reinstalled. 8.1. if all else fails you may need to use the gs regisrty cleaner jeffry posted to tr site
2003-12-11 10:52 PM
2003-12-11 11:01 PM
2003-12-27 10:22 PM
