Installation & update
installation of the last hotfix NED for AC15 ---:(
Hello
i recently updated AC15 with the last AC15 - hotfix( dutch version) NED
After the insteallation the installotion -box indicated to click finish
When starting AC15 the following appears( see below):
AC15 cannot atart because....
possible solutions: hotfix failed to install, you have serveral version of AC some of them not hotfixed
I still had AC 13 en AC 14 installed, ac14 was uninstalled, but the warning keeps reapaering.
When the warning sifgn is clicked away AC 15 start up
=> how can i be shure the hotfix was properly installed
=> how can I resolve the problem, so the warning sign doesn't appear
Has any had the same problem
regards
mathias
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Hi Mathias,
we have an other wiki article which describes the cause and the solution of this issue as well: http://archicadwiki.com/Bugs/HotfixInstallWarningMessage
Katalin Takacs
