laptop resolution
Hi all
Just quick question, I looking at getting a toshiba laptop with 17" screen but the highest the screen resolution it will go it is 1440x900.
Do you think this will be a high enough resolution to work with archicad or should I find a different laptop with a screen that can go to a higher resolution.
Thanks
3 Replies 3
Link
You can see by the results here that a resolution height of 900 is on the minimum end of the scale.
I wouldn't like to work with ArchiCAD at that resolution, but you could still do it. Others have. Maybe someone here could post you a screen shot of ArchiCAD at that res? I would but am on my Mac right now and it all seems too hard.
Link.
Eduardo Rolon
Applications -> Utilities (with Finder active, Shortcut Cmd + Shift + U ) -> Grab
menu Capture
select Screen
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I would say that 1440x900 is a bare minimum for productive work. My current MacBook Pro is 1680x1050 and is quite nice. If I were getting a new one right now I would probably go for the 1920x1200 though the tools and palettes might be a bit tiny.
In general: more pixels = better.
