2013-12-14 05:34 PM - last edited on 2024-03-27 03:49 PM by Aruzhan Ilaikova
2013-12-14 06:48 PM
2013-12-14 10:49 PM
2013-12-14 11:17 PM
2013-12-15 12:10 AM
2013-12-15 02:19 AM
Transferring data between computers with Apple's Migration Assistantfrom the wiki
/!\ Warning: Transferring user data to another computer via Apple's Migration Assistant to another computer with a newer OS X version (i.e. Computer A running OSX Mountain Lion 10.8 to Computer B running OS X Mavericks 10.9) is not advised and may result in corruption of ArchiCAD and BIM Server software.
The recommendation is that you first back-up your project files and Teamwork data, then uninstall any GRAPHISOFT software from the original computer, perform the Operating System migration, then re-install GRAPHISOFT software on the new computer. Failing to do so may result in you having to fully re-install your operating system on the new computer and install all programs from scratch along with user data.
another Moderator
2013-12-15 03:20 AM
2013-12-15 05:30 PM
2013-12-17 03:10 PM
venecasper wrote:My universal experience (in all versions of the Mac OS and ArchiCAD) is that nothing from Graphisoft will work properly with either the Migration Assistant or Time Machine. I've experienced this many times over the years, so I now assume that everything from GS will have to be manually reinstalled. It's strange, because everything else works - OS, apps, documents, settings… but not ArchiCAD.
Thank you Karl and Eduardo. I'll give it a go tomorrow and let you know how it all works out.
cheers
2013-12-17 06:21 PM
