nvidia geforce6600gt problems
hi I have as it seem a general problem with msi nvidia geforce 6600gt. while u open 3d window the screen doesnt show the whole 3d but a part of it and you need to regenerate 2-3 times the screen before you get the whole 3d. is there any solution to the problem I have used the the settings in troubleshoting window of the gc advenced settings
5 Replies 5
Djordje
Do the video card test (lower left of the main ArchiCAD Talk page, red letters), isolate the problems. There are Registry patches, but a driver update often solves it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ive had the same problem with every Nvidia card used on Archicad.
I think you have to live with it.
I've tried new drivers, switchin cards...etc...etc...
I have same problem since i upgrade my drivers, and i hate my asus 6600 gt cuz of that. Probably something with archicad cuz that problem only occure in archicad !
So, probably GS will have to deal with that problem and i hope that AC 10 will not have this BUG !
NFS
I've reported this elsewhere in the forums a couple of times. Ed Brown of GS support noted that the OpenGL refresh problem is corrected by turning Vertical Synch to OFF in the nvidia settings.
An updated driver won't help, because the setting will still be the same. No need for registry editing ... just the nVidia settings under display properties. You'll see that this is the setting used in their pre-defined settings for various games, too.
This is not a GS bug. (I don't often get to say that! 😉 )
Hope that solves your issue,
Karl
Carl u r wonderfull !
It works !
But archicad 10 must do that automaticly cuz it says that option is controled by aplicattion !!!!!!!
Anyway, thx man, now i love my 6600 gt again !
NFS
