As usual, OpenGL drivers should be loaded from the Manufacturer (but in the case of Dell, they often have their own drivers). Try these first.
And in ArchiCAD? Nothing spectacular you can do otherwise then enabling it in the options. The rest is not in ArchiCAD's hands.
There are options in Windows to disable (or lower) hardware acceleration, but they usually are set at full power, so chances are small that this is the culprit.
Does OpenGL work fine for other applications? E.g. the Windows OpenGL-screensavers or Quake or 3D-software, like SketchUp, 3ds max, Lightwave... or anything else you might be using?
Archicad-user since 1998
my Archicad Book
