professional quadro cards vs. regular gaming cards
does archicad support professional graphic cards (like fireGL or quadro)?
if yes, does it have any advantage over regular gaming card with the same chip?
http://geizhals.at/589544
vs.
http://geizhals.at/554793
thank you.
34 REPLIES 34
KeesW
Arcadia
I've been using Archicad with gamer cards since 1996 and have never had an issue with any of them. Perhaps I don't know what I am missing!
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
I belive quadro has a better memory-optimized drivers for running multiple instances of archicad, versus single-application optimization for a geforce-type card.
Other than that, Graphisoft gives a complete rats ass about optimizing for quadro cards. This work from Autodesk is miles better, and they seem to actually be talking with Nvidia and AMD about developing the software/hardware relationship. Graphisoft only recommends mac's, if not in clear text, in certain ways of putting things that suggest mac is the preffered platform inside Graphisoft.
Johag,
On the following page:
http://helpcenter.graphisoft.com/technotes/video-cards/recommended-video-cards-for-archicad-18/#8220...
you can read this:
GRAPHISOFT cooperates with:
* Nvidia to test and certify video card drivers for the Nvidia Quadro FX, Nvidia Quadro and Nvidia Quadro K series. This product line is recommended by GRAPHISOFT for ArchiCAD 18.
* AMD to test and certify video card drivers for the AMD Fire Pro series. This product line is recommended by GRAPHISOFT for ArchiCAD 18 as well
I'm also trying to figure this out. As in other programs i noticed that a simple GTX 970 is superrior in Maya to a 3x more expensive quadro card.
Since there is no benchmark, like Cinebench we have actually no real info on that matter.
One thing I noticed, there is no real difference between a HD 7870 and GTX 770, while in every other program the GTX 770 is significantly (25%) faster.
I did very large and very complex 3D scenes on these cards, but Archicads 3D viewport engine does a terrible job.
That's why I don't think that a 1000$ quadro would be any faster than a 300$ 780Ti, which is superrior in all other 3D programs.
Well there is one option, which is that the GPU usage of non-professional cards is not 100% on purpose.
We run a small very small company and buying 10 pieces of K4200 because of that is a rip off. It's cheaper to use other software.
People want to know real number like SPecviewperf, cinebench, where we can see the FPS count, video memory usage ETC, GPU utilization.
If a program uses 40% of gaming GPU and 100% of quadro. It means that the software is not using it properly. Not that nvidia or amd pay you to do that to run 100% on pro cards.
I am considering to buy a Titan X with 12GB VRAM, but if it's not used by the software, we have to buy a Quadro card, which will be in other programs waaaay slower.
I would be nice to know more.
Paul King
Mentor
Arcadia wrote:
My experience with gamer cards has put me off them completely. Even low end pro cards will be a much better option. Try getting a previous generation pro card on ebay - it can save a lot of money.
My experience is exactly the opposite! The worst performance and greatest visual corruption issues have accompanied the 'professional' Quadro cards, while even half the amount spent on latest generation gamer card will perform better on any meaningful real world benchmark for ArchiCAD.
Most of the purported speed and quality benefits of Quadro actually seem to apply to AutoCAD rather than ArchiCAD - something to do with AutoLisp optimised drivers.
This performance gap is likely simply a function of price and technology - the same money (the only meaningful way to compare cards is within a given budget range) buys you an earlier generation low end 'pro' card or a current generation top of the range 'gamer' card. With an extra year or two to iron out bugs, and improve manufacturing and graphic drivers etc, and millions of beta testers worldwide, a mass produced new card is usually going to beat a small run of older cards targeting a small market.
And if you use GPU rendering - (i.e the Octane plugin or similar) , this is a no brainer.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
Exactly my experience too.
Same here, comparing cards such as 5850, 7770, 750 to K22000, K5200 W7100 is just sooooo wrong and misleading.
It's the same since AC 16 and is still going on.
Plus one.
I have a 3gb R9 280 at home and a 4gb firepro at work. The $300 home card outperforms the $1000 work card in almost every way.
I'm pretty sure it's just down to pretentiousness. Professionals wouldn't be seen dead with a mere 'gamers' card.
shtarkel
Plus one.
What is the model of the Firepro card that you compare to the R290?
shtarkel
Have you all looked at the tests with different polygon count - very interesting. New test page for Archicad 19 - http://helpcenter.graphisoft.com/technotes/video-cards/recommended-video-cards-for-archicad-19/
Gamer cards are scoring too low?
It's a W5100.
Which brings me to my theory on how Archicad uses graphics cards.
I think, that it's all down to memory.
My firepro can work on bigger models faster in 3D, because it holds more triangles in 4gb before it has to spit them out to normal memory.
R9 280 has 3gb of faster ram so can regen smaller buildings faster than the firepro.
Renders are entirely down to CPU.
CAD people make a big deal on how accurate Quadros and Firepros are, but I don't really care if a few pixels go missing when I'm whizzing around editing in 3D - it's so small as to be not noticeable.
When accuracy is required, obviously it's there in the publishing (ACAD code), and in the renders (CPU).
So, if you work on big buildings, get a lot of memory in GPU, otherwise 2 or 3gb is fine for residential (what I do).
I hope this helps
