"this keyplug requires a different activation process"
Can not get the code meter to activate for ac18, any thoughts?
see the error message in my subject line.
Thanks
6 REPLIES 6
Eduardo Rolon
Are you using the License activation tool or the old website method?
http://www.graphisoft.com/downloads/licensing/
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
I downloaded the codemeter software and installed it and followed the instructions
Eduardo Rolon
Did it work?
AC27 US/INT -> AC08
another Moderator
no, I keep getting the same error message.
Thanks
Im waiting to hear from archicad support but version 19 may be out by then.
Do you have any news on this matter? I'm having the same problem and my distributor isn't answering.
Thanks.
Katalin Borszeki
Hi guys,
Try activating the key with the upgrade site
https://upgrade.graphisoft.com
and if the same error message appears please do contact your local distributors with the actual number of the key. Tx
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
