ā2006-08-07 06:50 AM
ā2006-08-07 10:34 AM
ā2006-08-09 07:31 AM
~/archiben wrote:i've just run the render again with 'activity monitor' active . . . all four chips are showing as having fired up and the CPU usage is showing at 220.5% (both processors running) . . .
2. there is something wrong with the quad . . . or something wrong in the way that lightworks address dual-cores . . .
ā2006-08-09 09:35 AM
~/archiben wrote:Very.
1. mactel is good.
3. boot camp public beta still has a long way to go before the windows hardware drivers are using the chips as efficiently as OSX?It's not BootCamp, it's Windows. My MacBook Pro is
ā2006-08-09 09:46 AM
Lennox wrote:It's already done. My MBP is faster than anything at one of my client's offices - and that's running Windows. It is even better running OS X. (I'll have to test it against the special rendering workstation at my other client's place.)
After years of Apple computer lagging behind PC's in rendering, it would be great if they took the rendering speed crown from PC's again.
ā2006-08-09 11:17 AM
Matthew wrote:I've heard memory handling is much improved in 64bit Windows (required for letting Archicad use more than 2GB memory when renderingin Windows, as I recall it from other threads in this forum).
ā2006-09-15 05:07 AM
CadConsult's wrote:. . . which comes in at 9.6 seconds for the 3D window generation and 10 minutes 12 seconds for the render!
LightWorks Rendering Engine
Initialization : 0.00 s
Model generation : 9.60 s
Rendering : 612.58 s
Termination : 0.00 s
Elapsed time : 622.18 s
ā2006-09-15 09:06 PM
ā2006-09-16 01:25 AM
~/archiben wrote:
as a follow-up, the guys at cadconsult here in NZ ran the same file, same settings, same render on their macbook 1.83GHz, 2GB Ram with integrated intel graphics card. . .
pretty good considering the price of the macbooks when compared with the macbook pros and the xeons!
btw - has anyone got a xeon and wants to run the same file for comparison?
~/archiben
ā2006-09-16 02:10 AM
Adalbert wrote:it is indeed so. mactel is good!
Is this so only 10'12"
