“undo" function disabled
hello,
the "Undi", "Redo" function is always disabled in 5 minutes, how shall I solve this ?
Thanks
1 Solution
The 'Saving recovery file - ultra safe' has nothing to do with the undo/redo.
The 'Undo Limit' is what setts how many undos you can do.
However no matter what you set for that, there are certain command in Archicad that will delete or clear the undo queue.
I found this in the Reference Guide.
Warning: The undo queue is cleared entirely whenever you do the following operations:
– Delete or add a story, or change story height
– Update a Hotlinked module
– Send/Receive commands in Teamwork
Go to post
2 Replies 2
Hello, Barry,
What I am doing now is just simple command eg copy move, setting etc.
Rrgards
