uninstall ArchiCAD 8.0
When I run uninstallation of ArchiCAD 8.0 I'm getting error on the very begining which is stoping the process. I'm geting the same error when trying to install 8.1 version. I still can use version 8.0
Can somebody help me.
Thanks
7 Replies 7
You need to provide more information. Computer, OS, etc...
Thanks
You didnt mention the error message, this could be handy.
I'm rinning winXP Sp1 on pentium 3 733 Mhz 384 RAM
No message on the error box, just Error & the OK buton which kills the process. It's the same when I launch installation of 8.1 from the CD.
Djordje
I would first try to install 8, choosing the Repair option, then install 8.1. Or after re-installing, uninstall 8, then install 8.1, rebooting (Shut Down/Restart) in the meantime. Uninstalling without the CD is not recommended.
You have to be Administrator.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I've tried that but is showing that error on the very beginning of the installation.
What do you think about clearing the Archicad 8 on the registry and deleting archicad 8.0 dir from program files, have you ever tried this.
All sorted. I've installed Ad-aware 6 pro and scanned my machine, after that I've been able to unninstall ArchiCAD 8 and install 8.1 as normal.
