13 W Doubel hang window - skin does not turn in
Is this a fact or I am not capable .....
HAs any of you encountered this
6 Replies 6
Complex wall?
Post a screen shot?
Inside, outside?
I have problems with windows in C.P.Walls.
Haven't figured it out yet. Looks fine outside,
trim hangs in too far inside.
Problem with doors in C.P. Walls I've solved.
lec
Skins do not turn
This is from where I try to return the interior furred out wall. Same problem with most of windows, I must be missing some new setting.
This is what I wanted to achieve
Erika Epstein
Try the attached.
It's not spelled out, but first you set the skins for one side and then the other.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Did I present what i you look for? see the pic.
