Keckelhoff
20 Solo Wallhole location?
Hello - I am working on Archicad 20 Solo. I have created a custom window with slabs. I cannot find where to designate the slab for the wallhole. The Slab Selection Settings has an option for Element Classification, but there is no option for wallhole. Under ID there is no option for selections of classification, only a box to type in. How do I designate the slab as a wallhole?
Thanks!
-KE
It is just the main slab ID that you need to designate as "WALLHOLE".
When saved as a door or window object this will automatically be converted to the wallhole in the 3D script.
This is not needed with rectangular openings - only odd shaped ones.
Keckelhoff
Thanks so much!
-KE
