2d door symbol strangeness
My doors were showing up in the plan as double line representations. For a reason I don't quite see, the doors are now shown as single lines for the door Anybody know how to fix this?
4 Replies 4
Have you changed the scale? Some door symbols are scale sensitive.
no, It has done that before in 7.0 when I changed scale, but I checked the scale and it still reads 1/4". Is there some quick key I hit to make them go to the single line?
select the door tool. then 'edit' select all doors. then get to the door preferences. go to parameters and then to options and then to 2d detail level and you can make it 1. scale sensitive 2. detailed 3.one line double etc. or off.
aahatimo
shae,
i wonder if it was a 2275 build 'feature'. i did not change the scale either. i had to go in as archibot mentioned and change 2d settings from scale sensitive to detailed. 2d door views are back to normal now.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
