2d dwg contours and/or 3ds model to mesh?
If I have a 2d dwg file of extensive contours but with no z-value, what is the best wat to get this to a mesh to make a 3d site model? I have one already made as a .gsm but its just a shell so I cant use SEOs on it...would there be an easier way to convert the shell to a mesh solid?
Thanks!!
5 Replies 5
Ah i got it....forgot you can use the magic wand to trace lines as well.
Stress Co_
More info/ links HERE
Marc Corney, Architect
Red Canoe Architecture, P. A.
Djordje
Maybe Model solid added to the 3D script would work?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
couldnt get that to work....but that doesnt mean much as my scripting knowledge is about 0...
The MASS command needs the j1 and j2 mask values
set to 1 and 4 to make the MASS command a solid.
Peter Devlin
