‎2009-03-04
03:19 PM
‎2023-05-24
12:40 PM
Rubia Torres
‎2009-03-04 04:46 PM
‎2009-03-04 04:55 PM
‎2009-03-04 05:01 PM
‎2009-03-04 05:05 PM
‎2009-03-04 05:08 PM
Karl wrote:Karl, If this isn't hijacking the thread, why png? I tend to use jpg.
(There are options for this screenshot that can change the format it is saved in - for example, I use the visual interface in Onyx to set it to save in PNG format for posting to these forums, but that's not important here.)
‎2009-03-04 05:42 PM
Erika wrote:To avoid a hijack, I started a new topic here:
‎2009-03-05 01:52 AM
Karl wrote:I know you were speaking MAC but in Windows I just open the "2D full view" window, place a marquee, copy and paste into the "Preview" window.
Yes, it is the same issue. Erika gave the answer - take a screenshot.
Since you're both on Mac, it is pretty easy: cmd+shift+4 gives you a crosshair cursor. Drag as close to a square around your placed symbol. The capture goes to your desktop. (There are options for this screenshot that can change the format it is saved in - for example, I use the visual interface in Onyx to set it to save in PNG format for posting to these forums, but that's not important here.)
Open the saved screenshot (typically on your desktop) in Preview, select all, copy and then open the "Preview Picture" window (bottom button in GDL editor) and paste into there. Voila.
Easiest way to create the actual symbol of course is to just paste your 2D elements into the "2D Symbol" window of the GDL editor.
‎2009-03-05 02:58 AM
Barry wrote:Thanks, Barry. I found that same option in the com.graphisoft.AC 12.0.0 <etc>.plist file on Mac under Input just now. But, enabling it doesn't really work for this purpose, as the copied image is tiny, and is not adjusted to fit the available 128 x 128 preview area. So, Mac folks may be stuck with screenshots for now, unless there is another setting...
If you get an error message to say that the clipborad is empty there is a Registry entry that can be changed to allow the copied image to be place in the clipboard as a bitmap image - set "Copy to picture also" to be on (value = 1).
‎2009-03-05 08:40 AM
