3D hotspot
Hi fellow gdllers
I need some input on how to make a 3D hotspot to use as snap points in 3D and in S/E windows.
Archi Terra has an hideous example of something like it.
I would like to have a very simple shape like a cylind or circle, but with only ONE snap point -or hotspot. Any ideas??
Best regards
Nicolaj Hvid,
copenhagen
3 Replies 3
Erich
You just want to add the hotspot to an object? Then try:
CYLIND h, r
HOTSPOT 0, 0, 0
HOTSPOT 0, 0, h
Where h is the cylinder height and r the radius. This code will place a single hotspot at the top and bottom of the cylinder.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Hi Erich
Thanks for your quick reply
This was my first idea as well. With a zero hight cylind I get a nice planar shape with ony one hotspot.
But this is for use in my "Totalstation to Archicad tool" mentioned some posts ago, and the use will most likely be in the S/E window, and here I am not able to ommit the hotspots on bounding box and I only require One and only one representation of the mesured point.
Best regards
Nicolaj
Erich
Is this boolean turned off?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
