2005-10-13 09:36 PM
2005-10-17 11:17 PM
2005-10-17 11:43 PM
2005-10-20 02:44 PM
Peter wrote:Peter,
Dan,
Just curious about two things.
One, how did you make the hole infinitely small ?
I mean, how did you define infinity in your code ?
Two, you say you locked the the A and B size of the hole to 1/4".
Why so large ? I have found the GDL scripts containing dimensions
of 0.001" work fine.
Thanks,
Peter Devlin
2005-10-20 07:23 PM
2005-10-20 07:31 PM
A label apparently can't access the roof pitch value so you used something that could.The label can access the pitch value. The problem is that it cannot tell the direction of the pitch.
2005-10-20 09:05 PM
2005-10-20 10:19 PM
Peter wrote:Peter,
Dan,
It occurs to me that maybe you could make a "roof accessory" object
for your label...
2005-10-20 11:09 PM
2005-10-21 04:48 PM
The label can access the pitch value. The problem is that it cannot tell the direction of the pitch.you can type 'down' in the available window...great thing to have. thx dan
2005-10-21 06:24 PM
Peter wrote:Ok,
Dan,
That's great.
Which accessory parameter defines the direction ?
I was just looking at those parameters and it seemed
the likely candidate was ac_ref_coords but I haven't check it out yet.
Thanks,
Peter Devlin
