‎2024-03-11
09:22 AM
‎2025-01-30
12:32 PM
Aruzhan Ilaikova
We have created new objects for a client in A25 and it´s work fine. But now the client need them to also work in A23 and it not work. How do we make them work in A23 also?
Solved! Go to Solution.
‎2024-03-11 08:06 PM - edited ‎2024-03-12 09:44 AM
Can you clarify what you mean when you say you ‘load the object’?
The steps should be as follows:
in AC25
1. load objects into the embedded library
2. Save As to AC24 pln
in ac24
3 open the pln you just saved on step 2 The objects should still be in the embedded library from step 1
4. Save as to AC 23 pln
in AC23
5. Open the pln saved in step 4
6. Open library manager and the objects should still be in the embedded library
7. export the objects to a folder on your computer and then you can share them as required.
edit: corrected wrong version numbers.
‎2024-03-11 09:33 AM
1. Install AC23
2. Convert your objects to XML or HSF using LP_​XMLConverter from AC25
3. Convert your objects back to GSM (or Library) using LP_​XMLConverter from AC23
https://gdl.graphisoft.com/tips-and-tricks/how-to-use-the-lp_xmlconverter-tool
‎2024-03-11 09:44 AM
Ok, now to an other problem A23 is not working on macOS Sonoma, that we are useing....
‎2024-03-11 11:15 AM
LP_​XMLConverter is a command line utility (you don't have to start AC).
Maybe it is possible to run it on Sonoma anyways...
‎2024-03-11 12:24 PM
I believe if you run the LPXMLConverter from the ac26 install folder you can pass the version you want to convert the gsm to. It maybe be GDL version not archicad version though.
If that all sounds a bit too complicated, add the objects to the embed library and then back save the pln through ac 25 and ac 24. And then extract extract the objects from the ac23 version of the file.
be aware, back saving objects can result in them not working if you have used functions that don’t exist in the older versions. 25 to 23 should be pretty safe though.
‎2024-03-11 02:45 PM
Thank´s for input. Yes that was a bit too complicated. But I manage to back saved it from A25 to A24, and it work fine in A24. But not from A24 to A23 when we load the object they dont even show upp in library manager?
(we managed to start up an old computer with A23 on it)
in AC25
in ac24
in AC23
‎2024-03-12 07:46 AM
Thank you for your information!
It´s not possible to open AC24 pln in AC23 (step 4). When I save AC24 pln to AC23 pln and then open it in AC23 I can see that the embedded library is there, see pic, but I can´t reach it? I have export it from AC23 but then i can´t load that folder in to AC23.......
‎2024-03-12 09:32 AM
Got it working now, had to save the AC24 in the older macOS system also, then it worked!
Thanks!
‎2024-03-12 09:43 AM - edited ‎2024-03-12 09:43 AM
Oops sorry I got my version numbers all messed up. I’ve adjusted my post now. But good to hear you got it working. Cheers.
