Tom Krowka
AC 15 Window Bug?
It appears that the windows (or at least this one) are not drawing correctly. Setting for this window is 7'-4", and the window hole is correct. However, it leaves a four inch gap at the bottom. If I turn on the sill, stool and apron, those elements fill in the hole.
However, the window should extend to the botttom of the wall hole, and the trim should go around the outside of the hole. I've tried all the settings that I thought would be applicable; I even thought maybe the window was open in the 3D settings. Can't make it work.
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
0 Replies 0
