AC 9 Profiler Question
How do i make this vase using profiler???? I have tried all night and no luck.
4 Replies 4
Dwight
what do you get?
Dwight Atkinson
Dwight
I remember that a revolve is tricky because you must always revolve AROUND a centerpoint, not ON or AT the centerpoint.
Get your Status Bar up to watch instructions.
Select the ceterpoint of the fill to be revolved.
Click way from that point to set the revolve centerpoint.
THEN: Move the cursor again - as little as one millimeter - and click to start the revolve.
Double click will make a full 360.
This small offset leaves a tiny cylindrical hole thru the profile.
Candle holders done this way.
Dwight Atkinson
is this the correct profile of the object?
Dwight
Better to use a fill, and always draw a section in the positive quadrant.
You know… from high school algebra where the graph to the upper right of the origin was x+, y+.
Less chance of the thing turning inside out.
I'd allow a thickness inside at the bottom that was more gracefully curved - your section looks like a cheap blown bottle rather than heavyweight crystal.
Get an expensive crystal vase and diamond cut it down the center. Scan the section. Then you'll be certain.
And be sure to increase the refraction on your glass to simulate crystal - something in the LightWorks archive on this.
Dwight Atkinson
