Please read all the way thru this post.. there are several issues...
1. So my object uses the old <DRAWINGNAME> as the text for a RICH TEXT BOX... again, this worked since 2003 up until AC21-4022
2. I cannot get anything from the AC_DrawingName parameter..
Either shows an error (String type expression expected)
or <AC_DrawingName> if I use that punctuation.
3. I have also tried to dumb down the RICH TEXT to just TEXT2, but no luck there either.
4. I've tried creating a Parameter blank to fill with AC_DrawingName, but that does not work either.
It is not shown in the GDL Manual as a REQUEST feature... so I did not go that route.
Any insight would be exceptionally helpful... I need to print next week and did not want to back down to 3005.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
