AC11: IE Marker
I'd just like to verify something before I embark on another GDL adventure...
It doesn't look like the Marker I want (see attached) is possible with the provided IE Markers in AC11 -- true? Typically, we will want to have one common Marker for each IE group, the Drawing ID being inherited from "The first placed drawing of the viewpoint" (all elevations of a room treated as a single drawing).
With the "One common Marker..." selected, the choices are limited to "Outer Text" and "Inner Text"; only with "Individually..." selected do you have the choice of "First Row Text" and "Second Row Text" (I do realize these are two different Marker objects). Am I missing a setting somewhere, or am I going to have to create my own Marker???
37 REPLIES 37
When modifying the Marker for my needs, I basically replaced the "First Row" of "Inner Text" as Tom suggested (plus I got rid of a bunch of stuff I didn't need and customized the Interface Script (see attached):
TomWaltz wrote:
The real magic:
	sInnerText1 = "<MARKERDRAWINGNUMBER_R>" + AC_DrawingGUID_1
	sInnerText2 =  "<MARKERSHEETNUMBER_R>" + AC_DrawingGUID_1
The Marker seems to reference the North or "Top" placed drawing first, followed by the East or "Right" if the North is missing, followed by the South if both North and East are missing, etc.
TomWaltz
In case you want an interior elevation marker that tells you what all those AC_DrawingText variables are:
Tom Waltz
kevin b
TomWaltz wrote:
Yeah, I noticed that. According to Tech Support, they could not find a good way to make a single marker with off-orthogonal views.
But that doesn't explain why it doesn't work with 2 or 3 orthogonal views. Seem like a bug to me.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
TomWaltz
I thought so too, but GS claimed it was "by design"
Tom Waltz
kevin b
Doesn't make sense, especially given that it looks like you can put in the rectangle, get all four views and 4 points on the marker and then select the individual line (or lines) for the views you don't need and delete them. The symbol then remains with only the remaining 2 or 3 views you want. IF the marker works with less than four, why can't it work just defining 2 or 3 to begin with instead of having to go back and delete. That smells like a bug to me.
I'll buy the couldn't figure out what to do for non-orthogonal views and/or more than 4, but if there's a workaround like I described, that's a bug in my book.
kevin s burns, AIA
massachusetts, usa
Windows 10
TomWaltz
Yeah, they thought counting to two involves the numbers 3 and 4 once in a while..
I also like the "Browse" button that cannot be activated.
Tom Waltz
Stress Co_
Does it work? When I delete 2 views.... the IE Marker's inner text no longer shows the referenced layout number. Is this a bug... or do I need to adjust a setting??
The 2 views are on a layout sheet.
Marc Corney, Architect
Red Canoe Architecture, P. A.
My experience is that when the top, always the top, view is turned off, the layID fails to resolve. I let them know. IEs are still very buggy IMO.
My workaround is to use multiple single-sided IEs with the markers stacked. Real convenient. I believe this is similar to the Tom Waltz pre-11 method.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Stress Co_
Thanks James.
I had not noticed, but your exactly right.
It only changes when the top view is deleted.
I switched to manually indicating the sheet #'s, but will try your (& Tom's?) workaround.
Not fixed in 1086.
You'd think a new tool that failed utterly in a plurality of cases would get more urgent attention.
Remind me, why should I upend my workflow every twelve months?
James Murray
