cremsberg
AC12 garage door frame alignment in wall
This is a garage door (D1 Garage 4 21). Notice how the frame does not sit within the wall as it should. I have this same problem with other garage doors in AC12 library. What possible settings might help fix this? Is anyone else having this problem?
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
Hi Claire,
I can confirm this bug in the (US) D1 Garage 4 12 object - the frame is in the wrong place in 2D and 3D.
The other 6 garage door types work just fine for me, though - it is only this one where I see the problem. Unfortunately, this is the only one that has an overhead track for the door, so is the most useful for US residential work. 😞
I'll report it.
Karl
