AC21 Stair - Reverse Walk Line - Options missing in teamwork files.
I noticed that with the most recent AC update (5021) the AC21 Stairs had been fixed to give the option of reversing the walk line on different floors. (ie. arrow point down on upper floor and arrow pointing up on lower floor)
Unfortunately, this only seems to have been corrected in the solo projects I work on. If I take a stair that has the correct walk-line orientation, copy it from a solo project, and paste it into a teamworks file, it reverts back to the older AC build which did not give the option to reverse per floor.
Solo File - Stair settings Teamworks File - Stair settings All computers on the teamworks file are using the 5021 build. Is there something I am missing here? Or is the issue just yet to be corrected for teamworks files?
Much appreciated.
Lucas
I think you might find this option is in the latest library update - not the actual Archicad update.
Check you have the latest library installed as well.
