AC26 objects not rotating to 3D camera
jkershaw
Anyone else running into this issue?
The offending elements (thus far) are all the People Symbols. They actually seem to be auto-rotating, but they are rotating the wrong way (presenting the narrow end to the camera) no matter what rotation I enter into the object settings.
The occurs in the 3D window in Parallel Projections.
The workaround is to use a Perspective Projection, set the rotations, and go back to the Parallel Projection. However, if you Rebuild and Regenerate, the objects auto-rotate the wrong direction again.
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
This is working as designed.  Archicad objects only have the ability to detect the camera location in perspective views.  If you want to view the object in a parallel view (looks like a presentation elevation in this case?), you need to turn rotation off.  This might result in you having to have one set of entourage in a layer for elevations (etc) and another for perspectives.
AC 28 USA and earlier   â€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Interesting. I don't recall this being the case over the years, but I believe you. Thanks for the reply.
13.2 macOS Ventura
