2005-01-18
05:47 AM
2023-05-24
12:11 PM
Rubia Torres
2005-01-18 03:59 PM
2005-01-18 08:20 PM
2005-01-19 03:44 AM
2005-01-19 07:22 AM
Karl wrote:Karl, John appreciate your input. Use my G4 only for CAD. 60GB hard drive with about 18GB used, so I have plenty of space. I backup to ext 120GB drive.
I see no noticeable delays on my G4.
I assume you're only loading libraries from your local disk....consensus that performance degrades as the percentage of free space gets less than 20%.
2005-01-19 07:34 AM
Aussie wrote:Glad to get your response John, this time of year can be busy. You are too kind commenting that selection is slow. And restarting has no effect, it's slow straight out of the box.
I note that Archicad seems to slow down over time and a restart of the app fixes things. Even just trying to select an object in the normal setting window can be slow.
2005-02-17 10:00 AM
2005-02-17 10:39 PM
David wrote:Hi david, its not anyone particular object or file. Just every so often the library dialogues and selection actions slow right down. Actually I havent noticed it for a while, so maybe system/archicad updates have helped.
Hi John
I use an eMac in the office and notice no appreciable slowness when open objects or their dialogues. This is true even when working on a 500mb pln file.
So I can't reproduce your problem
Can you send me one of the objects you are having the problems with?
And or any other details which might be appropriate
thanks
David Shorter
GRAPHISOFTAUSTRALIA
2005-02-18 04:08 AM
