Eduardo Rolon
AC9 Special Edition Lib Door Elevation Display Problem
I just found out that if you are using the US Special Library some doors are not changing their pen settings correctly. The one I am using is:
Wood Internal Door SE09 D1 1Sidelight
In the previous SE when you changed the colors for the door the glass inset in the door panel (Narrow Lite 2) changed to the one specified. With the revised SE library it does not and it stays with a very "wide" line weight" that I have not been able to change. If you choose the panel option "Narrow Lite 1" it displays correctly using the pen settings specified for the door, but if you change it to "NL 3" the pen changes again to the wide one. I tried also with D1 Entrance Side 1 with the same problem.
Not good...if anyone knows how to fix it I will apreciate the help
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
0 Replies 0
