ASAP help about tensile roof GDL.
today i create a tensile roof with the basic shape lib. and at the beginning, it was all right, then i dont know what i did the tensile roof become the wireframe in 3D window and even i render or change the 3d-view to any mode, it is all like this, just has black line wireframe, even rebot the laptop, it is still no working.
does anyone know how to fix it or is it a bug?
thanks
my name is Steven, and a 3rd year student in Australia
Attachment is showing what is hapening...
[/img]
undefined
16 REPLIES 16
BTW.. all other lib. parts works all right...
only this one, and it is very importnt that i will use it for next coming project.
only thing i remember is i just change the structure dimension of it then it become wireframe mode forever!
Dwight
IS the object on a solid or wireframe layer?
Dwight Atkinson
check again, it is in a solid layer
Dwight
Now I've tried it and you are right - I get the wireframe.
And Tensile Roof 11 also does it when used in Archicad 12.
I wonder how long it has been this way?
Dwight Atkinson
so, i guess nobody use this one ever in any project, 2 of my friend got the same problem one month ago, this is the bug in archicad, i guess
the only way is to wait for next up-date? hope
Dwight
I looked at the code and other than the fact that an array is erroneously attached to the material definition, there seems to be no change.
Dwight Atkinson
i agree, the tensile roof itself has no thickness at all...comparing with all the other objects in its same group, but i wonder how this thing works in 11 but not 12..
Dwight
Try with a different object - download from our Object Depository "Mesh 3D" that can be manipulated into one of the roof segments.
Dwight Atkinson
