Abnormaly HUGE objects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-11-18
11:40 AM
2023-05-24
11:52 AM
Rubia Torres
Just today I created a custom door, which was rather quite simple, and ended up with a 177Mo object!
The final size is seemingly random, an object ranging (for example) from 40Mo to 90Mo depending on when you save it. Also, sometimes (but not always) the same object, saved in a new project, can be much reduced.
Saving the same object from the 2D window gives 50Ko files so there seems to be a problem specific to the 3D window. Therefore, when I can I save from 2D, but sometimes need the 3D window (different angle etc...).
I have heard that others have had this problem, is there a work around?
As we work on a BIM server, the objects are automatically embedded so before we realised where the problem was the file ended up at 664Mo (compressed) and started crashing ArchiCad as the computer did not have enough memory to backup the file. Taking out the offending objects reduced the file size by 600Mo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-19 03:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-19 03:58 AM
Select the object on the floorplan, then go to 'File'>'Libraries & Objects'>'Open Object' (or CTRL+SHIFT+O) to open.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-19 10:27 AM
I have only the parts that I wish to save selected, there are no other elements present in the 3D window.. I have also opened the 3D/2D script(s) of the saved object and they are very short as expected.
While testing where the problem might come from, I came across another problem, maybe there is a link?
I copied the door I wished to save into a new project (so as to be sure that there was only the door in the project and no residual 3D in the RAM?), the jpeg texture I had applied came with it, so I changed the materials on the objects to default materials (all faces separately).
When I saved the object it was still large (6.54Mo) AND it had saved the object with some materials that were not present in the constituent parts - in fact it kept the material from the original paste and not the material that I had asked it to show.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-23 09:50 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-23 01:21 PM
I would take a look at reinstalling and it's possible e your problem will be fixed sooner than later. I had a problem with my REDO command not working and I solved it with a simple uninstall-reinstall of AC 14. Took me about 15-20mins to do the whole thing (my setup is also simple so mileage may vary).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-23 05:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-23 09:20 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-23 11:14 PM
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-29 04:06 PM
Always use small files as texture. After all, it's just a texture. Using large images will not just create large objects, but will hurt rendering times too.
