About Door/Window Markers and the Schedules in AC
Regarding the Door and Window Markers in AC,
Is there a way to tweak the given markers in terms of changing fonts,
pen numbers and location vis a vis the door/window ?? I've been searching and haven't found the path ...
Regarding the Schedules, is there a way to override and recalibrate the window/door numbers to start at #1 where I want it to be.
In one project, I'm finding that AC is numbering my windows starting at #14, plus there are windows with the exact same dimensions
with different numbers..
TIA,
Naftali
still ACv8.1
Stress Co_
Naftali:
This may answer part of your question... select the door and open the Selection settings .......
Shalom
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
Shalom
Marc
Hi Marc,
This answers ALL my questions !!!
Many thanks,
Naftali
This is what the Element ID Manager (EIDM) helps with, under the Calculate menu. Do a search of the forum for EIDM, as well as look at the help files.
Otherwise, you need to renumber in the I.S. itself, renumbering similar groups if that is your scheme, or one by one using the Info Box (last resort!).
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
