2024 Technology Preview Program
About embedded library
How can i know the position of "embedded Library" ??
Embedded Library objects are stored within your project file, not an external linked library. You can select items in the Embedded Library and Export them to an external location if you want to, to use them in other projects.
Hi S2art, I have tried to do that, but I have not been successful. I am certain that it will be something straightforward and obvious . Can you pls tell me the steps?
Off Topic: My prime reason is to extract the Modular door and window and put them in an external container so that I can address the duplicates issue that has crept up since downloading these two objects. One would have thought that any common code would be stored in a single location.
See if THIS THREAD helps. It discusses the MJO and the need (or not) for duplicate macros.
