About taking out Gld objects from a *pla file
I have troubles with the library's and want to rebuild it and therefor i want to know how and if I can do that. Please help me!
Linn
4 Replies 4
When you open your .pla file, choose to save your objects on disc. Then I would save the file as .pln.
After that I would change the GDL objects that is wrong and after that I would save it as .pla file again.
Hi, I dont have any choice to store on disk. I have Directy from archive, to a folder or select library... in the dialog box when i open the file.
Eduardo Rolon
"To a folder" is the same as "to Disk".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
when i take it to i folder/disk it doesn't take all the objects with it. Just the folder structure...And i cant load it again and use the same objects.
