Adding Libraries Directory Bug
I've have this problem with AC 13-14 on several different machines on several different installations. When I open the Library Manager and add a library, if I open the add library dialog again, I will be up one level in the folder hierarchy.
With my strategy of library management, this is a minor but very frustrating quirk. Every time I add libraries I have to re-drill back to where I need to go (which includes scrolling and looking for the folder name). And I can not see any obvious reason for this so it more than likely it's a bug.
2 Replies 2
Same here. It is annoying.
It is fairly annoying!
I've snuck around it by creating a folder on the desktop that has shortcuts to the libraries I want to load in it.
Then all you need to do is select that folder as your library and away you go.
I think that mau have been a Ben Cohen tip actually!
