Adding Window Parameters
After you have created your new window, how can you add extra parameters? I created a couple of new window types but forgot to include the "Finish" parameter. I would like to add this parameter to the window settings but don't know how?
2 REPLIES 2
You will need to open the GDL object and add a new parameter in the parameter list.
Make sure it is a text type parameter so you can type in the name of any finish you want in the object settings parameter list.
You can also add a VALUE list in the parameter script so you can have a list of finishes to choose from to save typing and errors.
You are now getting into the realm of GDL scripting.
Hello,
For example in the value script;
values "finish" "Paint A", "Paint B", "Paint C", custom
The name of the parameter in this example is finish
HTH
