Adding a RADIUS to a steel beam in the object libray!
Hi everyone,
I am using ArchiCAD 8.1 and need help on adding a radius on a steel beam so that i can use it as a rafter in a curved roof. I would greatly appreciate it if somebody could help me out by either telling me how to do it or just doing it for me.
thanks.
15 Replies 15
Aussie John
if I had to script a parametric curved beam I'd use the tube command.
Alternatively build it on the plan ( as if in elevation view ) project it in 3d elevating from the top ( so you see the real top) and the save as GDL object.
There probably is a standard object that does it, but someone else will have to direct you to it
Cheers John
[/size]
hi,
i am new to making or editing objects so i dont know alot about them.
what do you mean by the tube command?
thanks
Aussie John
it is one of the more complex commands. I suggest you look at the GDL manual.
Cheers John
[/size]
hi.
here is the beam that i am trying to add a radius too. if anyone can help i would really appreciate it.
thanks.
2 easy methods
1-gdl object
'web beam curved' object in the standard library
building structures>steel structures>spaceframes
it's got holes in it
just give the holes a zero radius and they'll go away
2-trussmaker
draw an arc in a S/E window for the centreline of the beam
select arc
menu>extras>trussmaker>create truss
set type, orientation and size of profile
(increase curve resolution for a smoother beam)
hth
bill
Vitruvius
Or you could just draw it using the Slab or Wall tool. That would work, as is, or if you're ambitious it could be saved as a GDL object. The User Manual has a good description of saving GDL objects.
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Thanks for your replies.
i know about the "web beam curved" but i want to be able to
curve the beam that i have posted. as it allows you to select the section type and weight easily.
thanks again.
Aussie John
actually on closer examination the tube command cant follow a curve path
Cheers John
[/size]
thanks again.
