2009-03-02 07:52 PM - last edited on 2023-05-26 11:27 AM by Rubia Torres
2009-03-02 08:49 PM
2009-03-02 08:55 PM
laszlonagy wrote:it looks like ArchiCAD 11 to me !
If you start Editing the Curtain Wall in 3D, you can switch to the Frame Tool and insert any Frame. The only restriction is that the new Frame must be between two existing Frames.
2009-03-02 09:21 PM
2009-03-02 09:27 PM
2009-03-02 09:31 PM
paultp wrote:Indeed, it seems that you can't add more vertical divisions to the curtain wall included in the doors library. But if you look in the windows library, the curtain wall in there can do that.
I want to do a basic curtain wall with a double door. No big deal. The problem is I want more vertical divisions.
2009-03-02 09:32 PM
2009-03-02 09:34 PM
2009-03-02 09:36 PM
adytc wrote:Basically, the same solution as Erika's ... only 5 minutes later
