Adjustable shower hose
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2017-04-06 10:32 PM
I thought the new NURBS suite of commands may help, but after researching a bit, trying to decipher the GDL Reference Guide, and actually trying a couple of commands, I’m not so sure (couldn't get them to work).
Any ideas would be appreciated.
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-07 03:01 AM
If you are using it now and can move one end then there is no reason why you couldn't make it move the other end as well.
The problem either way is that it will change the length of the hose so if it needs to be a set length you will need to adjust all the intermediate path nodes also.
If you are not fussy of the length then just adjust the end nodes (and of course the leading and trailing end co-ordinates.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-07 05:16 AM
What I'm really after is to get a TUBE to follow a NURBS path...but I don't think the new NURBS commands are up to that level of sophistication yet.
Do I mention that Revit could do this, or would that just be rude
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-07 05:40 AM
(It does appear to be locked so maybe you don't have access to it)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-07 05:50 AM
You would need the centre point and radius of the drape curve which would be based on the distance apart of the inlet and outlet.
Then use sin and cos to plot points along the curve for your TUBE.
Of course you know the start and end points.
I have done it using REVOLVE for the curve and PRISM for the vertical tubes (prism rather than cylinders because you can control visibility of the ends.
Again a very uniform curve.
The advantage of the TUBE is it would be all one element.
I have used a tube for a more natural shape on a bath spout with shower outlet but I did not make it adjustable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-07 06:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-07 06:08 AM
@Barry: Thanks for that. That gives me a direction for exploration. Cheers.
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-10 11:35 PM
Next time I'll do some research into B Splines, as I think you can better control the smoothness of the curve at the low point. The parabola is a bit too pointy for a hose.
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-11 03:50 AM
https://en.wikipedia.org/wiki/Catenary
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-04-11 05:01 AM
Mindmeister Mindmap
-- since v8.1 --
