2010-03-05 09:26 AM
2010-03-05 09:27 AM
2010-03-06 03:49 AM
2010-03-07 10:14 AM
2010-03-14 04:23 PM
2010-03-14 04:26 PM
keith wrote:3DS is a much better than DWG for this sort of thing.
Another way if you have sketch up pro or a trial version of pro, you can export the model as a dwg., make sure you have surfaces set to export.
Then you can open the dwg as a "object" and bring it into ArchiCAD. This is a bit dirty in terms of editing the materials of separate parts.
But if you need an object quick this is a good way
2010-03-14 07:37 PM
2010-03-14 08:09 PM
keith wrote:Much better. Maybe even texture maps, but I haven't tried this yet.
Matthew,
[3DS is a much better than DWG for this sort of thing.]
will this give you better surface material control?
Thanks
2010-03-14 08:16 PM
2010-05-20 08:52 AM
