‎2011-01-06 09:54 PM
‎2011-01-06 10:41 PM
‎2011-01-11 08:17 AM
‎2011-01-11 02:08 PM
ztaskai wrote:So if these parameters are present in the part (and presumably set correctly) this will enable the "All Relevant Stories" option for that part?
There is a way to tell ArchiCAD about the real height of the object and after thatall relevant storieswill work. Set the parameters 'ac_toplevel' and 'ac_bottomlevel' using the parameterscommand.
‎2011-01-11 04:39 PM
Matthew wrote:Yes. Just one thing I didn't write earlier. Their correctness is tested in exacly one way: the top has to be above the bottom. Other than that, these parameters are trusted (since they are new and don't have legacy usage).ztaskai wrote:So if these parameters are present in the part (and presumably set correctly) this will enable the "All Relevant Stories" option for that part?
‎2011-01-11 07:37 PM
ztaskai wrote:Cool. I'll have to start incorporating this into my parts. I have been getting away from all the old bounding dimensions (A, B and ZZYZX) due to legacy issues and quirks in their behavior. Are there plans for this to supersede the ZZYZX values in the info box (elevations) and pet palette (stretch height)? Or is this already the case? These are the only reasons I still use ZZYZX.Matthew wrote:Yes. Just one thing I didn't write earlier. Their correctness is tested in exacly one way: the top has to be above the bottom. Other than that, these parameters are trusted (since they are new and don't have legacy usage).ztaskai wrote:So if these parameters are present in the part (and presumably set correctly) this will enable the "All Relevant Stories" option for that part?
‎2011-01-12 06:20 PM
Erika wrote:Thanks for posting Erika (and for the straightforward NO, ha). The other floor plan display options would work for some columns, and not for some. Otherwise I would have to create a dedicated layer to not have those columns show up on my roof (or even foundation) plans. But there may be no need since I did a round-trip test with the complex profile columns and IFC/Revit models. So far they showed up fine. Thanks for the vote of confidence - that's what I needed.
No.
The other floor plan options work such as one story up and down, would that suffice? I recall this coming up before.
Re using a custom profile and IFC,: this use, on a completely symmetrical object, rather than a non-symmetrical one such as an eave trim should be problem free. BUT do a round trip test.![]()
Non-symmetrical custom profiles require the user to think ahead so that the direction they draw the wall/beam is always the same. Having available Mirror image custom profiles can also simplify modeling. If you are doing quantity take-offs, this too should be factored in to your choice of solution.
HTH
Matthew wrote:Since I'm still curious about this, is there a simple way to set these parameters? I see them in the column parameters list but do not know what to do with them.ztaskai wrote:So if these parameters are present in the part (and presumably set correctly) this will enable the "All Relevant Stories" option for that part?
‎2011-01-13 09:07 AM
Matthew wrote:Note, that ZZYZX is there for a reason: the user can find the primary dimension parameter in any object at first glimpse. So whenever applicable, you should make the ZZYZX parameter available when producing objects for public use. This goes for A-B parameters also.
... Are there plans for this to supersede the ZZYZX values in the info box (elevations) and pet palette (stretch height)? Or is this already the case? These are the only reasons I still use ZZYZX.
Matthew wrote:No and there are no plans to replace A & B. As I wrote above, they serve a general usability purpose. Plus, ArchiCAD uses them to determine the (estimated) 2D boundig box of the objects in several functions.
Are there similar parameters to replace "A" & "B". Then we could be done with the last vestiges of the old 26 parameter limit and the legacy quirks they carry.
‎2011-01-13 03:29 PM
ztaskai wrote:In the early days GDL was limited to 26 user parameters which were the letters of the (Roman/English) alphabet. There were also 52 globals which were a letter followed by an underscore or a tilde. Some of these were reserved for the user. I don't recall when this changed, perhaps version 5 or 6.
This 26 parameter limit doesn't ring a bell here:) Please, let me in on it
‎2011-01-15 04:24 PM
