Alphabetize List
Anybody know a trick for alphabetizing a list in GDL?
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Frank Beister
One of the basic programming issues. Are you looking for an algorithm or a ready to use script? Best should be bubble sort, I guess.
Comparing two strings can be done by < or >
From brain to keyboard:
dim t[], s[]
! ### set source
t[1]="one "
t[2]="two "
t[3]="three "
t[4]="four "
! ### preset destination
FOR i=1 TO VARDIM1(t)
 s=""
 NEXT i
! ### sort
 p=i
 FOR j=1 TO i-1
  IF s>t THEN
   ! insert element
   FOR k=i TO j+1 STEP -1
    s=s[k-1]
    NEXT k
   p=j : j=VARDIM1(s)
   ENDIF
  NEXT j
 s
=t NEXT i ! ### output PRINT s, "/", VARDIM1(s)
Viel Dank, Frank. I'll give it a go.
James Murray
Danke sehr mein Freund. I have been meaning to figure something like this out for some time. I hadn't expected the code to be so short. I look forward to trying it out.
