Angled windows
Hey, im pretty new to archicad, and i'm working with a project, and therefore i need a little help.
How can i make a window where the sides are angled? or where the bottom and top don't have the same measurements?
I have tried everything, and i only find ways to change the angle on the top..
I hope somebody here can help me:)
4 Replies 4
If you want a window you can adjust, you will need a purpose made object that will allow you to do what you want.
Try searching for 'polygonal window' in the window settings dialogue and download it.
Or if you want a one-off custom window then you can create it yourself.
https://helpcenter.graphisoft.com/knowledgebase/25564/
Szabolcs Miko
You also might find this article interesting about Custom Corners: https://helpcenter.graphisoft.com/user-guide/77607/
Szabolcs Mikó
Manager, Customer Support
Thanks!
Carstenem
Have a look at this tutorial, nice and easy solution:
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
