Learn more
Frank Beister
Angular_length_dimension
Can anyone enlighten me, what format string will be returned by
REQUEST("Angular_length_dimension" ...
I can not find it in the (german-version) settings dialog.
9 Replies 9
From gdl manual:
num= 60.55
format = ""
iii = request ("angular_dimension", "", format)
TEXT2 0,0, str (format, num)
Angular_dimension = angular dimension in according with AC's (angular) dimensional preference
CU mirco
Frank Beister
Thanks for the advice, but I was looking for Angular_length_dimension. Any hints?
Opsss
try this:
define style "mirco" "arial" ,3,1,0
style "mirco"
num= ang
format = ""
num2 = 2*PI*A/360 * ang
format2 = ""
ii = request ("Height_of_Style", mirco, altezza)
iiii = request ("angular_length_dimension", "", format2)
sposta = altezza/1000*A_
hotspot2 0,0
unid= 1 + unid : HOTSPOT2 0,0,unid,A,129
unid= 1 + unid : HOTSPOT2 -1000,0,unid, A,3
unid= 1 + unid : HOTSPOT2 A,0,unid, A,2
unid= 1 + unid : HOTSPOT2 A,0,unid, ang,4+128
unid= 1 + unid : HOTSPOT2 0,0,unid, ang,6
unid= 1 + unid : HOTSPOT2 A*cos(ang),A*sin(ang),unid, ang,5
unid= 1 + unid : HOTSPOT2 A,0,unid, ang,7
LINE2 0,0,A,0
LINE2 0,0,A*cos(ang),A*sin(ang)
ARC2 0,0,A,0,ang
TEXT2 0,0, str (format,num)
TEXT2 0,-sposta, str (format2,num2)
TEXT2 0,-sposta*2, num2
!----END
parameter -- type --
ang ----------angle ---
regards
CU mirco
Frank Beister
Thanks again mirco. I guessed it has something to do with the length of an arc. I think I do understand your script too, but I am looking for the setting, which I can request with this string. That "Angular_length_dimension" works inside REQUEST I found out. And that it is returned a length dimension too. What where is the user setting I can request with it.
There was a show-train in germany for AC5. When the Gurus from Munich showed us at Hamburg train station the new features I saw as last button in the option>settings dialog for dimensions a symbol for the units of curved measures. But it was not implemented yet. I think it was without function in the final AC5 or it was discarded. I haven't found it in the AC9 dialog. Maybe this is a relict of a functionality not implemented in the way I was once thought.
Hi Frank,
I've tried to change AC's angular lenght unit but the request don't work fine.
It's locked onto "m" unit.
Maybe this is a bug.
regards
CU mirco
Is not the same request but, for the moment, U can avoid this problem with "linear_dimension".
Frank Beister
I found someone, who can still run AC5. He found, that there are 9 buttons in the settings dialog for measuring units as I remembered. In AC9 there are only 8, because the angular length dimensions are now a special part of the linear lenght dimensions.
I will later post some screenshots. Unfortunatly it does not work in AC 5 either. I come to the conclusion, that its a function without functionality.
Frank Beister
Here a Screenshot of the AC5 settings dialog. (Thanks to Peter_h.)
You have to look to the third button from the left.
Frank Beister
And the same dialog in the AC 9 version.
You have right!
I don't know the existence of that button.
I use AC only form 6 version.
No, the angular lenght dimension don't work in according with linear lenght, radial and angular dimensions.
I don't think so,
infact you can change unit across the Standard pop up menu.
I think GS have lost the ninth button
CU mirco
