ArchiCAD 12 Casework
I have been using AC12 Casework and have run into a few issues that I believe could be bugs. Cabinet Base 2D 12 - Example when you have a sink and 1 draw turned on and you door style is 1 for some reason the draw under the sink is beveled even though that option is turned off.
Also Cabinet B-P 2D 12 has a bug. Example when you have an upper cabinet on and you turn on your knobs the upper knobs are for some reason shifted and are not in line with one another this occurs in styles 4 to 8?
Any help would be appreciated.
1 REPLY 1
Eduardo Rolon
If I remember correctly, it has already been discussed and confirmed as a bug.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
